1995 Dodge Caravan 3.0 problems
I have a 1995 Dodge Caravan 3.0 V6. When you take off from a stop, if you press the pedal hard, it dies. If you press it lightly it will go, but will stutter. We changed the fuel filter, fuel regulator, air filter, had the alternaot checked to make sure it was sending enough voltage to the fuel pump. It was good. I tried to change the plugs and wire, but I CANNOT get the plugs out. We can't get ANY sockets on the plugs. I am at my wits end, and want to blow the van up, but it is our only transportation. Can someone PLEASE HELP?!?!?!?!
You may need to remove the plugs from under the van, Not from the top. Sounds like you are having a misfire problem, and also clean the throttle body and linkages too.
