94 Caravan dies when I give gas
Old Jul 23, 2008 | 10:36 PM
highoctaneal's Avatar
highoctaneal
Default 94 Caravan dies when I give gas
I have 94 dodge Caravan 3.0 V6.Symstom is you must pump the gas pedal and depress gas pedal alittle bitbefore it will start, (before you simply just trun the key).The van will idle just fine when it starts, but when you give gas to it it will die whether it is in nuetral or in drive. Gas pedal must be depressed very very slowly in order for the car to move. Catalictic converter was replace 2yrs ago and there is no check engine light on, fuel pump has lots of pressure.This just happened suddenly.Can anybody help me?
Old Jul 23, 2008 | 10:58 PM
deezozdodge's Avatar
deezozdodge
Default RE: 94 Caravan dies when I give gas
Is therer a fuel filter for the van? Checked throttle cables?
Old Jul 24, 2008 | 10:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you replace the cat with a factory or aftermarket cat? Sounds like the exhaust is plugged.
Old Jul 28, 2008 | 10:12 PM
highoctaneal
Thanks to all who responed, I was able to fix the problem by replacing the oxygen sensor.
Old Jul 28, 2008 | 10:50 PM
deezozdodge
Did you replaced the O2 sensor after the Cat? Why no engine code?
