3 speed transmission
Old Jul 27, 2008 | 08:31 PM
uno23's Avatar
uno23
Default 3 speed transmission
hello to all, my brother and i removed the shifter cable from the transmission, including all the brackets that go with the cable, well on the transmission all that was left is a stub, when we tried to put it back together i wouldn't shift, is there a special way that the stub has to lign up and how do you know when its lined up?
its a 98 dodge caravan, 2.4 engine, 3 speed transaxle, if you guys have any ideas, they would be greatly apreciated....
thanks
Old Jul 28, 2008 | 12:09 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 3 speed transmission
Are you asking about the kick down cable or the shifter cable? The bracket for the kick down cable bracket is bolted with the dip stick tube.
