2003 caravan fuel pump & water pump problem
Old Jul 29, 2008 | 08:11 PM
fabio76's Avatar
fabio76
Default 2003 caravan fuel pump & water pump problem
I have a 2003 Caravan 3.3L and I need to replace the fuel pump and water pump. Can anyone tell me on how to do this?
Thanks
Old Jul 29, 2008 | 09:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 2003 caravan fuel pump & water pump problem
Fuel pump, you'll need to remove the gas tank. Water pump, you'll need to loosen the upper motor mount and pry the engine towards the trans. This so you can get the pulley out and then the water pump.
Old Jul 30, 2008 | 06:35 AM
deezozdodge's Avatar
deezozdodge
You can check out videos on how to do this at www.youtube.com or www.ehow.com. Type in what you want to research and click on the video tab. But, just as the Master Tech states is the way to perform it. Have plenty of rags or drysweep
