cranky in the morning
Old Jul 30, 2008 | 10:17 AM
nvrplay2ty's Avatar
nvrplay2ty
Default cranky in the morning
1996 4 cyl caravan, when the motor is cold it turns over fine but sputters before starting. Once its warm it starts fine. any suggestions. thanks
Old Jul 30, 2008 | 06:45 PM
deezozdodge's Avatar
deezozdodge
Default RE: cranky in the morning
Best way to diagnos is to perform a routine maintenance check. When was the last time you performed one?
Old Jul 31, 2008 | 11:26 AM
nvrplay2ty's Avatar
nvrplay2ty
so far i have done plugs and wires, as for diagnostics there no engine lights on
Old Jul 31, 2008 | 06:37 PM
deezozdodge
Did you check distributor and rotor? Did you make sure the gap on plugs are set correct? What about air filter? I mean doing a complete maintenance... Check the simple things first. There is another forum available called www.boxwrench.net. It may have some useful information. I'm sorry if I don't have the answer to your problem.
Old Jul 31, 2008 | 06:40 PM
deezozdodge
If you decide to go to www.boxwrench.net, click on COMMUNITY on the left side and it will take you to forums. It is a good forum, because you can search the exact situation.
Old Jul 31, 2008 | 10:42 PM
nvrplay2ty's Avatar
nvrplay2ty
gaps is right on. air filter is new... there is no rotor it has an ignition box all the easy stuff is done
Old Aug 1, 2008 | 06:15 AM
deezozdodge
Are you thinking something to do with fuel flow? Possibly fuel regulator or the filter? How's it doing now?
Old Aug 3, 2008 | 01:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
There is a tsb 18-05-96 for the early 96 vans and 1995. To replace the IAC motor. This is for cold start ups.
Old Aug 6, 2008 | 08:03 AM
nvrplay2ty's Avatar
nvrplay2ty
I dont know what it is fuel or air... will get a fuel filter and look into the IAC motor...thanks guys
