1996 trans leaking bad
Old Aug 4, 2008 | 12:14 PM
fastc14's Avatar
fastc14
Default 1996 trans leaking bad
hello to you all i am new to this forum but not to forums. i have a problem with a 1996 grand caravan 3.3 the trans. is leaking almost as fast as i can pour fluid in. i removed the acces cover that is nest to the oil pan and it is leaking out of there i am not familiar to the van so i am asking for posible solution or causes to the problem i have read that the torque converter are know for going bad but woul like some of your experences thanks
Old Aug 4, 2008 | 11:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
The front pump seals maybe leaking or the front pump bolts are loose, causing the seals to leak. in either case the trans needs to come out and replace the front pump gaskets and bolts too.
