2004 grand caravan driveabilty issue
Old Aug 4, 2008 | 10:23 PM
junior219's Avatar
junior219
Default 2004 grand caravan driveabilty issue
I have a 2004 grand caravan with a 3.3l. it has about 105 000 kms. it has a slight miss at idle, not enough to throw a code. I have absolutely no power, especially for the bottom end. it just lately seemed to get worse. I thought I has transmission issues, so I took it a tranny shop and there was no problem with it. any help will greatly appreciated
Old Aug 4, 2008 | 11:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
Just guessing, maybe plugged exhaust because no power. Have you replace the plugs and wire set? If so, did you ck the plug gap?
Old Aug 11, 2008 | 07:52 PM
junior219's Avatar
junior219
Thumbs down
I checked the exhaust for a plugged cat. it was ok. the plugs look good. the wires are about a year old. I am stumped
Old Aug 11, 2008 | 08:45 PM
master tech
What is your MAP/BARO sensor reading pressure. For here the baro would 29.0 to 30.0 . At higher levels the pressure maybe lower.
Old Aug 25, 2008 | 08:08 PM
junior219's Avatar
junior219
I had the fuel pressure checked, it is at 60 psi. the map sensor is 27.00-88.00kpa. I live in vancouver, canada. that is almost sea level.
