02 3.3flex fuel code p0172
Old Aug 26, 2008 | 04:32 PM
volsfan_301's Avatar
volsfan_301
Junior Member
Unhappy 02 3.3flex fuel code p0172
i have replaced the o2 ,ambiant,plugs,wires,map,fuel pump,injectors,coil pack and the van doesnt have an egr valve.I have also had the converter checked and it is ok. Can someone help me please
Old Aug 27, 2008 | 09:56 AM
master tech's Avatar
master tech
Site Moderator & Tech
I have a PDF file that may help you, But you will need a scanner to ck. If you want the file just send a pm.
Old Nov 28, 2008 | 12:34 AM
Cragar59's Avatar
Cragar59
Question 02 3.3flex fuel code p0172
I have the same issue with my 2003 Caravan 3.3 flex fuel. Have tried the injectors, o2 sensors, fuel pressure regulator, mass air flow sensor, no vacuum leaks detected. Still have the code P0172.
Was the problem found on the 2002 Caravan? If not, any ideas?
Thanks
