Fuel gauge briefly malfunctions
Old Aug 27, 2008 | 07:29 PM
blarneytalker's Avatar
blarneytalker
Junior Member
Default Fuel gauge briefly malfunctions
1998 Dodge Grand Caravan. 3.3L. The low fuel light and warning chime would both go off and the needle would drop slightly. Then all would go back to normal. Did this lead to the next problem? Car all of a sudden won't start. Can jump it and it runs fine. Battery tested good with a full charge. Still requires jump to start it. After attempting to start it without jump, when key is turned back a relay under the dash starts clicking.
Old Aug 27, 2008 | 09:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the battery and clean all connections. The battery maybe no good even if the tester show it is.
Old Aug 29, 2008 | 09:47 PM
RickMN's Avatar
RickMN
Try this article: http://free-auto-repair-advice.blogs...0gauge%20drops
Old Aug 30, 2008 | 11:02 PM
I own only Dodge's Avatar
I own only Dodge
i had a similar thing happen to mine, exceot when I would start it the gauges would all top out then slowely drop back to normal, after a few days my battery was dead. Rplaced it and now its fine.
