2003 Caravan SE knock in tranny ?
Old Sep 17, 2008 | 03:06 PM
pchelnyk's Avatar
pchelnyk
Question 2003 Caravan SE knock in tranny ?
Hi, our 2003 caravan makes a knocking/rattle sound only in drive or reverse and at idle, seems to fade with accelleration but could be its just masked by engine noise. Definitely stops when you shift to neutral or park. Any experience out there ? Tran fluid is fine.
Looking forward to some opinions
Old Sep 19, 2008 | 11:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may have a broken reaction plate for the reverse and overdrive clutches. Or a cracked flex plate. The transmission would need to be removed and inspect.
Old Sep 21, 2008 | 12:57 AM
rabbler's Avatar
rabbler
Good advice above but I would check and make sure the torque converter bolts are all tight first.
