01 T&C fan only works on high? power locks dont work either?
Now that I have the engine running right, I'm trying to tackle a bunch of smaller stuff to make this right. The heater/AC fan does not work on any other position than high. The rear fan responds the same. Even if I put the rear controls on, it still only works on high. I haven't dug too deep into this just yet, I was hoping that someone might be able to provide a little insight.
Also another problem is that we cannot activate the power locks from either of the two front doors. It still works from the FOB....
I'm hoping that both of these might be related, or relatively easy to fix.
Thanks for any suggestions.
Fans problem is most likely blower resistor , get that replaced . Not sure if there is 2 , one for the back and one for the front . For the locks try resetting the bcm by pulling the IOD fuse for a couple of minutes and see if that does anything . This will blow away your radio presets .
thanks for the tip!
Steve
