Wheel Stud
Old Nov 6, 2008 | 04:36 PM
zenon17's Avatar
zenon17
Default Wheel Stud
Perhaps I'm making this more complicated than necessary, but what is the easiest way to get out a damaged wheel stud on a 2002 Grand Caravan.
Old Nov 6, 2008 | 05:45 PM
floorslayer1's Avatar
floorslayer1
Either replace the bearing which will have new studs or remove bearing and use a BIG hammer and pop the old one out and then tap in a new one.
Old Nov 6, 2008 | 06:22 PM
TJeepman's Avatar
TJeepman
Best not to hammer away and damage the bearing. The stud can be pressed out. As to installing, it can be drawn in using a nut and lots of washers or oversize nuts.
Old Nov 6, 2008 | 07:06 PM
TJeepman's Avatar
TJeepman
Here are a couple of sites about it. Putting a force behind the hub to protect the bearing is a risky approach (might damage bearing) but it's often done that way.
http://penguinhosting.net/~bigmac/st...20replacement/
http://autorepair.about.com/od/fixit..._stud_repl.htm
http://www.automotiveforums.com/t290211.html
Cutting off the broken stud helps http://www.youtube.com/watch?v=JAcMwPCI6a0
