Newbie here...need some basic assistance
Old Nov 8, 2008 | 08:04 PM
drummer1279's Avatar
drummer1279
Default Newbie here...need some basic assistance
Hi all.. I just recently purchaced a 92 grand caravan se with the 3.3L engine. all I need to know are the transmission, oil crankcase and other essential fluid capacities so when I go to change them I don't mess up
thanks for your help
David
Old Nov 11, 2008 | 02:55 PM
andyg's Avatar
andyg
Oil with filter is 5 qts. Not sure about the trans but the owners manual might say if you have it. If not a simple pan drop is probably around 6qts. I used 12 when I flushed the torque converter through the cooler hoses after dropping the pan.
Old Nov 11, 2008 | 09:22 PM
Klabbage's Avatar
Klabbage
my 1993 3.3L takes 4.5 qts oil using the standard mopar oil filter. May want to take a look at the online repair sites (some are free) or get a cheap Haynes manual off an Amazon seller so you will have all your specs.
Old Nov 12, 2008 | 11:47 AM
drummer1279
thanks guys. as a side note, when I do replace the tranny fluid I use ATF+4 correct?
Old Nov 12, 2008 | 12:48 PM
andyg's Avatar
andyg
If you can find ATF+3 you can use it in your year van but I have not seen +3 around my area for a few years and I am using AFT+4 with good results. The good thing about +4 is that it is synthetic and can go longer between intervals but I still change it every 15k just to be confident in my trans.
Old Nov 12, 2008 | 05:26 PM
drummer1279
the transmission was replaced in feb '08 so I dont think that it needs changed just yet, but good to know I can use +4 without a problem. 5w-30 oil I assume as well?
Old Nov 13, 2008 | 07:32 AM
Klabbage's Avatar
Klabbage
See this link for the oil suggestions based on local air temperatures. You can get some other info you may be interested in as well, plus quick links to the retailer's products that match them. Your mileage may vary regarding the quality of their products, however.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I use 5w-30, though if I lived further south I would consider 10w-30 in summer. By the way, that first image regarding oil suggestions replicates what is in the owner's manual, which I presume you do not have.
