Speedometer Quit
Old Jan 5, 2009 | 11:38 AM
cableguy's Avatar
cableguy
Default Speedometer Quit
Can anybody help w/ this? 03 Town & Country (I know, it's a Chrysler) speedo spun all the way around. Everything else is working properly.
Old Jan 5, 2009 | 10:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know want cause the needle to spin all the way around? There two things you can do, 1st have the dealer recaliprate the cluster or 2nd, remove the cluster and tip the clusher upside down to swing the needle back to were it should be.
Old Jan 5, 2009 | 10:28 PM
eaglestorm's Avatar
eaglestorm
push and hold the odo button then turn on the key the cluster should recall you can let go of the button when all the lights of the cluster come on after you turn on the key. taking out the cluster and tipping it to swing around the needle wont work. Dealer can cal the cluster for you but it's not free
Old Jan 7, 2009 | 10:04 PM
TJeepman's Avatar
TJeepman
I have heard of this solution before on the Chrysler Minivan Forum. What causes the problem to begin with - weak battery??
