2000 Grand caravan electrical issue
Old Jan 12, 2009 | 09:42 PM
robb4640's Avatar
robb4640
Default 2000 Grand caravan electrical issue
We have a 2000 Dodge grand caravan sport that all of a sudden had this problem this morning
The turning signals, power door locks, blower fan all do not work at all, also the air bag light and the ABS light next to it remain on after the vehicle is running. I have checked the fuses and all seem to be ok. I have read on here that the air bag light being on may be related to the clock spring not working but that seems to be tied in with the cruise and horn which i have not check yet.
Any suggestions would be appreciated.
Old Jan 12, 2009 | 11:18 PM
master tech's Avatar
master tech
Site Moderator & Tech
With a test lite, ck the PDC under the hood fuse's 12 and 13 for the air bag,and Fuse 10 25amps and 102 40amp( green ) looks like a small box and fuse 11 20amp these are for the ABS. Still in the PDC fuse 14 20amp for the turn signal. Then go to the junction block inside the van, and ck fuse 6 20amp for the air bag. and fuse 12 10amp, this feeds the turn signal and ABS, Now you could have a problem with Ignition switch.
