Caravan Cooling sytem problem
Old Jan 17, 2009 | 02:47 PM
caravan89's Avatar
caravan89
Default Caravan Cooling sytem problem
Hello Forum,
Happy New Year to everyone on the forum. I haven't been at the forum since 8/2008.
I am having a problem with my 1989 Doge Carvan 2.5L non turbo. On June 2008, I had a friend replaced the timing belt as well as the water pump. The friend was not to knowledgable with the replacement of the timing belt. I had to get another friend to be able to start my car. Currently, I am having some problems with the heating system. At the begining of the winter I was getting some heat, but now I don't get any at all. I don't know if it is a problem with the thermostat or the water pump. I forgot to mention that I haven't replaced the thermostat in a year and a half. I pintched the upper radiator hose and I didn't feel any antyfreeze running. I will like to know if the problem comes from the thermostat or could it be the water pump. How can I tell if the water pump has gone bad. It has been very could here in New York City and I can't work on the car. I been changing the car from street to street in other to avoid getting a ticket when the street needs to be clean. I haven't been traveling far. Can the engine get damage If I only moving the car from one side of the street to another? I want to change the thermostat when it gets a little warmer . Your honest feedbak wll be greatly appreciated. Thank you
Last edited by caravan89; Jan 17, 2009 at 02:54 PM. Reason: I mispelled some words
Old Jan 17, 2009 | 07:17 PM
vabear's Avatar
vabear
Default Heat
i do not think it is the water pump, if that was bad I would suspect overheating of the engine. Does the temperature gauge come up to normal, if yes does it get there quick or slow? I would first suspect the thermostat, if she is stuck open or partiallt open then sufficient heating will not happen
Old Jan 17, 2009 | 09:15 PM
caravan89's Avatar
caravan89
Thanks vabear, this particular van doesn't have a gauge with a needle. It has a small round glass with the sybol of a thermostat. If the light goes on this symbol, it means that the engine is getting hot. So far it hasn't turn on. However, the fan on the radiator goes on after the engine has been runnig for 15 minutes
Old Jan 18, 2009 | 09:45 AM
vabear's Avatar
vabear
Default Cooling
These cars do have a temperature sensor that activates the fan at a given temperature, also most will activate the fan instantly if the AC is selected.
