Can you put a 2001 3.3 engine/tranny into a 1996 caravan?
The tranny in my 96 (3.3) went bad so I've been looking at options to fix it... The van has 187k on it and runs good but I don't want to spent $1400 fixing it. I have found a wrecked 01 with a 3.3 and good tranny with 120k and was considering swapping both the engine and tranny as a unit. The questions I have are: Are the subframes the same, ie can I unbolt one and directly swap the whole frame without having to undo all the half shafts, etc. and 2: Can I use the same electronics or do I have to change the ECM and other modules? Any and all advice is appreciated.
1996 is an NS body and the 2001 is a RS body. The engine will not work, the trans will only if you have a TRS on the 1996 trans, and if it does then you need to replace the flex plate from the 2001 and a jumper harness for the TRS. The last NS body was 2000. If you need more information just send a pm.
Yes, Mopar does make the harness and it cost about 110.00 dollars. And If you were in the san francisco area, I'll would just give it to you. I have three of them in my tool box.
Thanks again for all the info. I decided not to go this route mainly because of the miles on the 01 transmission. Since it has apparently never been cracked, I thought 120k is probably on the far side of needing rebuilt itself, so I don't think I want to do a replacement twice. I enjoy reading the formus- they are very informative and have answers you can't get anywhere else. I appreciate the time the specialists spend reading and answering the questions.
