new battery purchase help
Old Feb 25, 2009 | 06:26 PM
blacklake1967's Avatar
blacklake1967
Default new battery purchase help
I need to buy a new battery for my 01 Caravan tonight...I've never needed to buy one before.
What should I look for?
(I live in an area with cold winters...and like to camp, an crank the radio with the vehicle off.)
Old Feb 26, 2009 | 01:10 AM
rabbler's Avatar
rabbler
I've had very good luck with Costco batteries. Don't know who makes them though.
Buy the one with the highest Cold Cranking Amps that comes in your vans size.
Also see if the battery has it's reserve capacity rated. CCA tells you how much power the battery can put out. A higher reserve capacity means the battery will put out its rated CCA for a longer time.
Good luck
Old Feb 28, 2009 | 08:13 PM
ydde1937's Avatar
ydde1937
i have had very good luck with Duralast batteries from Autozone.
Old Mar 2, 2009 | 08:09 AM
chopper's Avatar
chopper
If you want your battery to last almost forever you need one of these,,,
http://www.aircraftspruce.com/catalo...er11-11671.php
I have three of them now and they're all plugged into something all the time.
There are solar versions also.
