04 Caravan Airbag Part #
Old Feb 28, 2009 | 11:28 PM
Freebie-1's Avatar
Freebie-1
Default 04 Caravan Airbag Part #
Looking for the Correct Part Number for the Airbag Module in a 04 Caravan or a 04 T&C Equiped with Side Seat Airbags.
Old Feb 28, 2009 | 11:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
Which one? Passager, driver or side air bag modules.
Old Mar 1, 2009 | 02:12 AM
Freebie-1's Avatar
Freebie-1
Default Control Module Part #
Need the Part Number on the Control Module on the floor in the center.
Updating my caravan to the 04 option with Side Seat Airbags & the New Module from Dodge appears to be the Wrong Part.
Was looking for a Owner of a 04 Caravan or 04 T&C with Factory side seat airbags to get the correct part number off their Module.
Old Mar 2, 2009 | 10:05 PM
master tech
The ORC module is 4727360ac, there is also a air bag module that goes into the B-Pillar 4686602aj. All parts are Mopar numbers.
Old Mar 2, 2009 | 11:29 PM
rabbler's Avatar
rabbler
Have you got all the related wiring harnesses?
Or a whole doner vehicle?
A job like that can turn into a real nightmare...
Old Mar 16, 2009 | 11:22 AM
Freebie-1's Avatar
Freebie-1
Master Tech
The First Module is the newer Module which replaced the 4727360AB Module used for Frontal & Side Seat Airbag Systems- the second Module you listed is actually the Origional Airbag Module for Frontal Airbags only.
Rabbler
I wish I had a working donner car to Scan, it might Help.
All the Upgrade Parts were purchased New from Dodge.
Yes it has been a 4 year Nightmare.
The DRB III problem shows a ACM Calibration Mismatch.
Looking for a way to add the RPO Code CGSS to either the FCM or BCM for the Van to accept the new Module & turn off the Airbag Light??
When I Bought the Van New, I thought the Van would have the Side Seat Airbags.
I started the project after viewing Chrysler Vin# decoding info stated that a 2D4 had supplement Side Airbags & a 2D8 did not - Just another in the long list of Misprinted Infomation from Chrysler.
Another Strange Item, when scanning the New Airbag Module, it indicated that the Knee Blocker was Enabled ?? - There is/was no Knee Blocker on the 04 Mini Vans as far as the Service Manuals & Wiring Schematics indicate.
As I haven't driven the Van more than 1700 Miles since New - I will Keep Trying to Find some way to correct the Problem or eventualy revert it back to the Origional Airbag System.
Nothing Like Sh-- Canning $2500.00 worth of parts to make you feel good.
Thanks for your replies
