1998 Caravan Problem--Need Help!
Old Mar 12, 2009 | 08:53 PM
nkcatwoman's Avatar
nkcatwoman
Default 1998 Caravan Problem--Need Help!
I have a 1998 Dodge Caravan v6 3.0 with 83,000 miles. It just started making a banging/rattling noise when it starts up and continues to rattle while idling, sometimes while driving, but stops when you hit the gas. It seems to be coming from the center rear of the engine. We have already ruled out the catalytic converter. Any other ideas?
Last edited by nkcatwoman; Mar 13, 2009 at 10:25 AM. Reason: ETA: banging at startup
Old Mar 12, 2009 | 09:02 PM
Nofrag's Avatar
Nofrag
How's the oil?
Old Mar 12, 2009 | 09:08 PM
nkcatwoman's Avatar
nkcatwoman
The oil is fine, never had a leak, regularly changed, etc. We just got back from a 2,000 mile trip and never ran low.
Old Mar 13, 2009 | 01:58 PM
surfit's Avatar
surfit
Is it "pinging?" Sounds like marbles rattling around? Try putting premium
gas in the van and see if it goes away. If it does, then your ignition timing is off.
I hope it's not the "death rattle," i.e., rod knock due to worn rod bearings
- need engine overhaul.
You need to find out exactly where the noise is coming from. Use a
stethoscope in the engine compartment to isolate.
