Acceleration Problem
Old Mar 18, 2009 | 08:41 PM
stikrz's Avatar
stikrz
Thanks a lot for that Chopper. That is the next thing I was going to try...the fuel pressure. I don't know how to do the rest, but like you said it's not giving any codes. I did hear a comment about the fuel pump either works or it doesn't, but I don't know about that. The coil however, might be something to check. How would check that out without buying a new one?
Thanks again.
Old Sep 28, 2011 | 10:18 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Originally Posted by stikrz
I can "creep" up to speed, but if I stand on it to pass it chokes!
My vote is for coil... Are you getting induction backfires when it chokes or does it just bog down?
Old Sep 28, 2011 | 10:34 PM
lovvorn's Avatar
lovvorn
Default Bad M.A.P. sensor switch on the intake manifold !!
Your map has gone bad !!! Replace & your good to go !!! My Thoughts Bud
