Tsb
Old Sep 29, 2011 | 12:33 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default Tsb
Here is a new TSB, And just wanted to share.
SUBJECT:
MIL Illumination Diagnostic Trouble Code P0339 - Crankshaft Position Sensor Intermittent
Set
OVERVIEW:
This bulletin involves adding a shim to the crank sensor and verifying the condition has
been corrected and only if necessary, replacing the flexplate.
MODELS:
**2009 - 2010 (JC) Journey**
**2009 - 2010 (JS) Avenger/Sebring/Serbring Convertible**
**2009 - 2010 (JK) Wrangler**
2009 - **2010** (LC) Challenger
2008 - **2010** (LX) 300 / Magnum / Charger
2008 - **2010** (LE) 300C/300 Touring (International Markets)
2008 - 2009 (L2) 300 (China)
**2009 - 2010 (RT) Town & Country/Grand Voyager**
NOTE: This bulletin applies to models equipped with a 2.7L, 3.5L, 3.3L, 3.8L or 4.0L
engine (sales code EER, EGG, EGF, EGV, EGL or EGQ) and a automatic
transmission.
SYMPTOM/CONDITION:
Some customers may complain of MIL illumination. No other symptoms will be noted or
experienced. Further investigation by the technician may find DTC P0339 - Crankshaft
Position Sensor Intermittent is set. It is possible that DTC's P0300 - Multiple Cylinder
Misfire and/or P1128 - Closed Loop Fueling Not Achieved - Bank 1 and/or P1129 - Closed
Loop Fueling Not Achieved - Bank 2 could be set along with P0339 - Crankshaft Position
NUMBER: 18-024-10
GROUP: Vehicle Performance
DATE: August 18, 2010
NOTE: P0339 - Crankshaft Position Sensor Intermittent must be set along with the
other DTC's listed above. If P0339 - Crankshaft Position Sensor Intermittent
is not set then this bulletin does not apply.
DIAGNOSIS:
Using a Scan Tool (wiTech) with the appropriate Diagnostic Procedures available in
TechCONNECT, verify all engine systems are functioning as designed. If DTC's other than
P0339 with or without P0300, P1128, P1129 are present then record them on the repair
order and repair other DTC's first as necessary before proceeding further with this bulletin.
PARTS REQUIRED:
Qty. Part No. Description
AR (1) 68061031AA Washer .022 (.56mm)
AR (1) 04736299AC Flexplate
