Crazy flashing headlights and all dash indicators lit
Old Apr 8, 2009 | 07:42 PM
tcmdr23's Avatar
tcmdr23
Default Crazy flashing headlights and all dash indicators lit
03 GC 3.8l "ALL" of the dash indicators will come on while driving or even sitting in park at idle. The headlights will also go on and off or even strobe! the vehicle still drives fine but nothing on the dash works. Help! This is a random occurance dry or wet weather.
Old Apr 8, 2009 | 10:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may start by ck'ing for stored codes in the bcm or cluster.
Old Apr 10, 2009 | 06:40 PM
great2c4me's Avatar
great2c4me
Default headlights, no power.
I just bought this problem, 00 ram van 3spd v6 off my friend. I know they were working about 8 days ago.
He told me that the headlights were flickering, and now do not come on... he didn't know what the problem was.
I tried looking to see if there was an exclusive headlight fuse, but I couldn't find anything in the 2 locations known - left side dash board driver side, and next to the battery. all my other lights work properly.
I found this, 'multi-function switch going bad' statement...
https://dodgeforum.com/forum/2nd-gen...ats-wrong.html
bottom of the first page.
Old Apr 10, 2009 | 09:43 PM
master tech
Disconnect one of the headlamp connectors and using a test lite, see if you have any power coming from the switch when you turn it on. if you don't, you may have a open circuit. The Ram Vans also had a fuse box inside the glove box too. My guess would be a head lite switch or multi fuction switch.
Old Apr 13, 2009 | 09:48 AM
great2c4me's Avatar
great2c4me
ya, I pulled out the headlight switch, turned it on, no current was passing through 1 hot point. upon disconnecting it, I saw some black carbon on that connector.
Bought one for $30 at autozone, (sw220). fixed the problem. I take it that it's a common issue.
