gas filter
Old May 13, 2009 | 10:32 AM
dodge250's Avatar
dodge250
Default gas filter
hi i have dodge caravan 2000 : 3.0 L
i need to know gase filter whear its located, what is throttle body? AIS moter. And last Q is for transmition oil change: is it ok to use motomaster ATF DEXRON III fluid for this van.
thank you .
Old May 13, 2009 | 09:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
The fuel filter is under the van. You need to let the part place know if you have a long or short wheel base. If the rear qt glass window looks short, then you have a short wheel base. you may have the three speed trans, ATF+4 is for all transmission. AIS( Automatic Idle Speed ).
Old May 15, 2009 | 07:58 PM
surfit's Avatar
surfit
Anyone, please tell me how easy it is to replace the fuel filter on a 2002
Caravan. I believe it is located between fuel tank and chassis.
Do I need to empty the fuel tank?
If I don't want to mess with draining the petrol I guess I should
let the dealer do it.
