05 Caravan-Driver power window intermittently wont go up. How to fix?
Old Jun 18, 2009 | 05:29 PM
chuckb's Avatar
chuckb
Default 05 Caravan-Driver power window intermittently wont go up. How to fix?
2005 Caravan the window goes down perfect. Sometimes when you put it up it will go 1/2 or 1/3 of way and quit. if you wait a minute and hit switch it'll go up another inch and quit. I can hear what sounds like the motor trying when I hit switch and it's not moving. what do I most likely need to fix it? Thanks.
Old Jun 19, 2009 | 06:56 PM
chuckb's Avatar
chuckb
ok, it's apart. how do I remove the motor assembly from the door. do those white fasteners just pop off?
the regulator seems fine. the motor moves slow thens tops ebven when not connected to regulator.
