Inner tie rod end
Old Jul 2, 2009 | 07:54 AM
stix309's Avatar
stix309
Default Inner tie rod end
1996 Grand Caravan, I have some play in the tie rod on the passenger side. I have checked the outer tie rod end and it is tight the movement goes all the way up the tie rod. I am assuming it is the inner tie rod that is the problem. Is this a job I can do to replace it or should I take to my mechanic
Old Jul 24, 2009 | 10:25 PM
Dukksoup's Avatar
Dukksoup
Yes this is fairly simple job to do, I would replace that ASAP, as your steering is pretty important!!
Old Jul 28, 2009 | 07:13 PM
MartymanVR6's Avatar
MartymanVR6
easy to do if you have the special tool or a good pair of channel lock pliers.....geometry of the wheels must be done afterwards
Remove the rubber boot and install tie rod,install boot with 2 tie raps
