2007 caravan 3.3 misses hesitates
Old Jul 28, 2009 | 06:26 PM
MartymanVR6's Avatar
MartymanVR6
Default 2007 caravan 3.3 misses hesitates
Hi I would like some expertise from you "dodge" guys..
Im working on a 2007 grand caravan 3.3 (not flex fuel) 20 000 miles on it
The car came in with an missfire/hesitation...at 40mph when I hold it and press so lightly on the gaz pedal keeping the rpm at 1500 the car missfires but barely....at any other speed or in acceleration the car runs smooth....
The owner of the car came n brought me 6 plugs and an oem wire set that i installed properly....(wires were making lil blue sparks with the cyl head)
I scanned it....no codes nothing....looked at the data everything looks normal...and i did a missfire counter with the scanner with a 15 mins test drive....nothing zero missfires no pending.....
Any knows problems with those cars? defect coil pack??
Any good hints to give me?
Im a german car specialist....worked on those for so long,iI dont know the common problems on American cars....
Old Jul 28, 2009 | 10:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck for a knock sensor on the starter side of the block. Unplug it, will not set any codes. Also ck the neg ground cable at the battery and injector ground too. Have the dealer run the vin and ck for TSB's or flash up dates.
Old Jul 28, 2009 | 11:24 PM
MartymanVR6
No TSB already looked for those....
Old Jul 30, 2009 | 10:51 PM
MartymanVR6
Grounds are clean and good......
Old Jul 30, 2009 | 10:55 PM
master tech
What is you barometric reading?
