P0003 Fuel Volume Regulator Ctrl Circ Low
Old Jul 28, 2009 | 07:51 PM
Blackthroat's Avatar
Blackthroat
Default P0003 Fuel Volume Regulator Ctrl Circ Low
Hi everyone. I have a 2005 Grand with 70000 km on it.
I just checked and go the above code.
Issues. The engine has a pinging sound at low rpm's and low speed.
I had the plugs out a couple weeks ago and the number 2 plug didn't look good at all. All gummed up. Almost like it is'nt getting a good spark. What should I be getting for resistance on the coils?
Thanks
Old Jul 28, 2009 | 11:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
The P0003 code is the same as P0201 thru P0206 for fuel injectors. You could have a wire grounded on one of the injectors. There is also a TSB 18-026-06 for pinging, Flash up date.
Old Jul 28, 2009 | 11:19 PM
Blackthroat
Thanks for replying. Well if it is an injector issue then that would explain why cylinder two plug looked like crap. So what you are suggesting is that I check and see if the injector wiring has crapped out.
Old Jul 31, 2009 | 11:48 PM
master tech
Inspect the injector harness for any cuts or shorting to the manifold. If they look good, then switch that injector with another cylinder.
