P0406 Diagnostic Detection
Old Aug 15, 2009 | 10:43 PM
kajamo240's Avatar
kajamo240
Default P0406 Diagnostic Detection
Just on last Wednesday I bought my wife a 2006 Dodge Grand Caravan and I already have a question about my new purchase.
~Today, my wife went for a drive and saw that the engine light came on. I ran the diagnostic on it and it came up with the error of P0406. After some time of searching the web to find out what this error is, I have found out that it is trying to tell me that the EGR sensor has failed/broke.
Now is this something that I can bring to the dealer and have them fix since its an emission problem and the van is so new or do I have to deal with this problem myself.... Hope its the latter of the two...
Thanks for your suggestions/comments...
Matt from Isanti, MN
Old Aug 17, 2009 | 12:16 AM
MartymanVR6's Avatar
MartymanVR6
EGR valve stuck in gum and crap either that or the tubing that goes to it......maybe guaranteed......
TKO intake cleaner and a vacuum pump and you can clean it yourself
Code might go away by itself after a few drive cycles if you clean it properly
Old Aug 17, 2009 | 09:15 AM
RickMN's Avatar
RickMN
Replace the EGR. Common failure.
Read this http://free-auto-repair-advice.blogs...-position.html
Old Aug 17, 2009 | 11:49 AM
kajamo240's Avatar
kajamo240
Thank you so much for the responses. This was extremely helpful!
Old Aug 22, 2009 | 04:02 PM
kajamo240's Avatar
kajamo240
Replaced the EGR and everything is in perfect working order! Thanks again!
Old Aug 28, 2009 | 11:54 PM
79MKII's Avatar
79MKII
Glad you got it fixed! I'm having the same issue right now with my 2005. I'm trying to buy an EGR valve for mine and I need to know if I have "Option Code (XZZ)". What on earth is that!! I've run the VIN and there's no mention of it. Anyone have a clue? I sure don't!
2005 Dodge Grand Caravan SE 3.3L
Old Aug 30, 2009 | 09:39 PM
79MKII's Avatar
79MKII
I read online that "XZZ" will be in the VIN if the vehicle has that option code - can this be true? Doesn't sound right to me but I really need to buy an EGR valve asap. My plates expire tomorrow and I can't pass the Ohio e-check with my check engine light on. Help!
Old Aug 31, 2009 | 08:32 AM
kajamo240's Avatar
kajamo240
Sorry, I have no idea what that means. I will try to do a little research for you. When I bought my EGR they just asked for the size of the motor. It was a special order part and it took a couple of days to get...
Old Aug 31, 2009 | 08:36 AM
kajamo240's Avatar
kajamo240
From what I can find, it seems that the option would be in the VIN. If its not, then get appropriate EGR valve. They arent too hard to difficult to change. I got mine from AutoZone and they were about $25 cheaper than anywhere else.
Old Aug 31, 2009 | 01:07 PM
79MKII's Avatar
79MKII
Thanks for the help. The 2005 has 2 different types and I've been told 3 different ways to tell what option code it has: On door jamb stickers, in VIN, on egr valve. I'll have to check the valve for markings but I'm guessing the vin or door jamb to be the correct way to tell. It's looking like my does not have the XZZ option which is good - it's the cheaper valve!
