1998 dodge grand caravan start problem
Old Sep 11, 2009 | 02:12 PM
babylon70's Avatar
babylon70
Default 1998 dodge grand caravan start problem
I have 1998 grand caravan3.3L I have problem with starting the van there is no ligghts on the dash the gages dosnt move when i turn the ighntion on and it dosnt start plz helpe thanks
Old Sep 11, 2009 | 06:17 PM
RickMN's Avatar
RickMN
No lights, no crank? First, clean battery terminals and ground cables. Then check for power at ignition switch before and after you turn the key.
Old Sep 16, 2009 | 12:10 PM
22dodge's Avatar
22dodge
the MOST common failure on Gen3 minivan dashes is broken solder joint on the cluster ciruit board. easy fix or just toss in a known good cluster.
