07 Dodge Caravan Steering problem
Hi,
When i stop my 2007 dodge caravan and turn the steering left or right some vibration will heard and feel.
i noted that the vibration increased when the engine temperature increased; etc when the engine is cold the vibration is less than when it hot.
please if there is any opinion..!
Thanks in Advanced.
Thanks in Advanced.
Hi,
I want to replace power Steering Reservoir's Fluid of My 07 Dodge Caravan, the owner manual says that it should be (MOPAR ATF+4 Automatic Transmission Fluid), the available type is (ATF Dexron IID,ZF TE-ML 03D/04D/11A/14A/17C,Voith G607) witch related for Castrol ???
Can I use it ?
Please Help ASAP
Can I use it ?
Please Help ASAP
