2008 Grand Caravan brake calipers
Old Oct 5, 2009 | 07:02 AM
xobxdoc's Avatar
xobxdoc
Default 2008 Grand Caravan brake calipers
I having trouble getting the caliper pins out to replace my pads. It appears there is a lock nut on the pin. It is a very thin nut that a normal wrench cannot grip. Is there a special tool for this or am I doing this wrong?
Old Oct 5, 2009 | 08:58 AM
shelbydaytona's Avatar
shelbydaytona
you need to hold the pin to remove the bolt, just take, i think a 13mm wrench and grind it narrow then take out the bolt. i only done brakes on 1 08 but its been a while
Old Oct 5, 2009 | 11:16 AM
RickMN's Avatar
RickMN
Yeah, that nut can be a pain. Try a small adjustable wrench (crescent style) or a cheap Chinese wrench that you can grind down.
