2001 dodge grand caravan no brake
Old Oct 5, 2009 | 09:44 PM
babylon70's Avatar
babylon70
Default 2001 dodge grand caravan no brake
hi all I have 2001 grand caravan I have problem withe the brake every time we bled the ABS pump with using the scane tool and after10 days I have no brake agen I change the master cylnder and bled it using the scan tool very god brake for 10-15 days and then no brake agen I chekt all the lines no leek I fund the air only on the front left weel can som one helpe me plz I need your helpe guys what to do with this van????????
Old Oct 5, 2009 | 10:17 PM
master tech's Avatar
master tech
Site Moderator & Tech
When you bleed the brakes after 10 days, are you getting air out of the system? If you are, try just doing a base bleed without the scanner. Also ck TSB's too. I think there is section on the forum for tsb's. If not let me know.
Old Oct 6, 2009 | 10:39 AM
babylon70's Avatar
babylon70
yes I do gft air on the system spesiuly on the left front and I do abase bleed and the air want finsh I have done that to many times
Old Oct 6, 2009 | 10:48 AM
master tech
Some how you are getting air in the system, reck all your lines to be sure the they are tight. Or you could have a problem with ABS pump assy. I also ck TSB's and found none.
