changing engin oil
Old Oct 6, 2009 | 07:02 AM
msmafr's Avatar
msmafr
Default changing engin oil
hi
I want to change the engine oil for my car (dodge caravan 2007), the manual says that the best oil type for the engin is (5w-20), the available types in markets is (5w-30 & 10w-30) only.
which type is better that I can use it??
help me please
Old Oct 6, 2009 | 07:21 AM
dhvaughan's Avatar
dhvaughan
i think either is fine.
the 5w30 is same (5) when cold, and a tad thicker (30) when warm.
10w30 is a tad thicker at both temps.
5w30 might be a little better choice for a winter oil.
Old Oct 6, 2009 | 08:32 AM
shelbydaytona's Avatar
shelbydaytona
Originally Posted by msmafr
hi
help me please
u must not be in North America? 5w30 would be just fine especially if u have higher miles but what have u been doing all along? or did u just get this van?
Old Oct 6, 2009 | 10:11 AM
TJeepman's Avatar
TJeepman
hi
help me please
The three most popular motor oils on the store shelves here these days are 10W-30 (most common), 5W-20 and 5W-30 (least common). Does your manual give you choices?
The 3.3L / 3.8L engines in the new Vans are calling for 5W-20 whereas the 4.0L, a more sophisticated engine apparently, calls for 10W-30. Go figure.
If stuck with using 5W-30, I wouldn't worry about it unless you have warranty considerations. I use 10W-30 mostly in my 3.3L and may switch to a 5W-20 or 30 for the cold months of winter.
Old Oct 8, 2009 | 02:21 PM
2002ACRNEON's Avatar
2002ACRNEON
I've found (bought and used) full synthetic 5W-20 for my '05 3.3L V-6 at WalMart.
I have also seen 5W-20 convential and full syn at Autozone and Advance Auto Parts in Maryland.
