engine wiring help
Old Nov 26, 2009 | 08:18 PM
Atremblay's Avatar
Atremblay
Default engine wiring help
Ok i need help with my engine wiring, I need to repair the sensor wiring as the original wiring was cut out when the engine was replaced by my grandfather a few years back and now i need to hook it all back up because i like to have all my gauges working. I do not have a manual with the harness wiring in it. so any help would be greatly appreciated. oops almost forgot it is a 1986 dodge caravan with a 2.2L engine.
Old Nov 26, 2009 | 10:12 PM
RickMN's Avatar
RickMN
Alldata or eautorepair your best bet. You're asking quite a bit for someone on here to post about 10 pages of wiring diagrams so you can save the $12 for a subscription.
If you can't afford the $12, try your local library. They usually have online access to online repair information.
Old Nov 27, 2009 | 05:05 AM
92dak5.24x4's Avatar
92dak5.24x4
seems like a dumdum type van situation. It's not possible in this forum to fix your van. time to take it to a professional. and why did you change your ID?
