Have a problem with a 96 caravan
the caravan is a 96 dodge caravan and it was running normal and sundely just died it was running in 30mph wen sundently bumm just turn off
the caravan have 1/2 of a fulll tank
the only thing is that i dont heard the fuel pump activating and the worse thing is that wen i push the switch all the way dosent cranck up. yes al the acc works radio a/c everything but dosent cranck up.
wat it could possible be ??????
it cood be allot of thigns. if it dont cranckup then yall cood have a prb with the batt cabls i no that if the (-) bat wire is bad it can keep the moter from runin or starting but still have radio and other stuff ok. i bet yall got a wiring elect prob and ware to start is with some testing cercuts and relays and stuff like that. i seen a van that woodent start cuz some critter ate soem of the wirs
Wow, the spelling is even worse. Are you guys from another country? If you can't hear your fuel pump running, you need to have someone diagnose why this is. A bad ignition switch, bad relay, bad fuse, bad wiring problem are all candidates for this problem, including the no-crank issue.
But before you get all upset because you're not getting an exact answer, be aware it is impossible to accurately diagnose a problem such as this thru an internet forum. It's all going to be guess and try. And depending on the level of mechanical aptitude, it may be beyond impossible to solve this issue. The BEST choice is to find a mechnic that diagnose the problem with the vehicle in their hands.
dj m
Welcome to the DF
First i would have the PCM ck'ed for codes. If the starter can not turn the engine, you will have a no start problem. Like the other guys had said you need to find someone to check the van out.
Welcome to the DF
thanks guys for the answers i will check those and tell all off about the van later. anymore suggestion are welcome
Trending Topics
maybe get a test lite them a cheap i think wallys world has them too from china. then get some wireing digrams thats like haveing a road map for the car. too bad there aint like gps for wireing so it would just say whats rong then i wouldnt have to think no more
Comments like this are exactly why I tend not to visit this forum anymore. Where's a moderator when you need one?
