Retrofit Automatic Headlights to 2008?
Old Dec 15, 2009 | 12:48 PM
mr_mike's Avatar
mr_mike
Default Retrofit Automatic Headlights to 2008?
I have a 2008 GC SXT with manual only headlights. Is there are way to retrofit in the automatic ones that are an option? Is it a matter of just changing the switch, or is there an additional sensor that would need to be added? First car in a while without automatics, and it's harder than it should be to remember to turn them on all the time!!!!
Thanks,
Mike
Old Dec 15, 2009 | 11:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may need to call or see the dealer,to find out what nneds to be added to have automatic headlamps. You also may want to ck if you can have the DRL actived too.
