My next issue....
Old Jan 3, 2010 | 06:02 PM
Bluestreak95's Avatar
Bluestreak95
Default My next issue....
im getting quite upset over this dam van. 96 caravan 3.0L.
Anyways now the wipers dont work n i mean both front and back. So that tells me its not the motors...i swapped the relays arround to check if it was the relays n nope still dont work. My guess is its the BCM. but what shud i check first befor i confirm that its the BCM?
Also if i go pull a BCM out of the junk yard do i need to get it re programmed or anything?
Old Jan 3, 2010 | 06:56 PM
92dak5.24x4's Avatar
92dak5.24x4
You SHUD get a wiring schematic and see if you have power at the switch and confirm other circuits.
