Check Engine Lite Codes (MIL)
Old Jan 11, 2010 | 11:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default Codes for gas engine and transmission
Here are codes for 1996-2001
charging
p0622 generator field not switching properly
p1492 battery temp sensor voltage too low
p1493 battery temp sensor too high
p1594 charging system voltage too high
p1682 charging system voltage too low
p0106 barometic pressure out of range
p0107 map sensor voltage too low
p0108 map sensor voltage too high
p0112 intake air temp sensor volt too low
p0113 intake air temp sensor volt too high
p0117 ect sensor volt too low
p0118 ect sensor volt too high
p0121 tps volt does not agree with map
p0122 tps sensor volt low
p0123 tps tps sensor volt high
p0125 closed loop temp not reached
p0131 1/1 o2 sensor volt shorted to ground
p0132 1/1 o2 sensor volt shorted to voltage
p0134 1/1 o2 sensor stays at center
p0135 o2 sensor heater failure
p0137 1/2 o2 sensor volt shorted to ground
p0138 1/2 o2 sensor shorted to voltage
p0139 1/2 o2 sensor slow to response
p0140 1/2 o2 sensor stays at center
p0141 1/2 o2 sensor heater failure
p0171 1/1 fuel system lean
p0172 1/1 fuel system rich
p0201 thru p0206 are injector control circuit
p0300 multple mis-fire
p0301 thru p0306 are cylinder mis-fire
p0320 no crank reference signal at pcm
p0340 no cam signal at pcm
p0351 coil #1 p0352 #2 p0353 ignition primary circuit
p0401 egr system failure
p0403 egr solenoid circuit
p0420 1/1 catalytic converter efficiency
p0441 evap purge flow monitor failure
p0442 evap leak small leak detected
p0443 evap purge solenoid circuit
p0455 evap leak large leak detected
p0460 fuel level unit no change over miles
p0462 fuel level sending unit volts too low
p0463 fuel level sending unit volts too high
p0500 no vehicle speed sensor signal
p0505,505b,505c,505d, and p0505e idle air control motor circuit
p0601 internal controller failure
p0645 a/c clutch relay circuit
p1281 engine is cold too long
p1282 fuel pump relay control circuit
p1294 target idle not reached
p1388 asd relay control circuit
p1389 no asd relay output volt at pcm
p1391 intermittent loss of cmp or ckp
p1398 misfire adaptive numberator at limit
p1486 evap leak pinched hose found
p1491 radiator fan control relay
p1494 leak detection pump pressure switch
p1495 leak detection pump solenoid circuit
p1496 5 volt supply output too low
p1598 a/c pressure sensor volts too high
p1599 a/c pressure sensor volts too low
p1695 no ccd message from body controller
p1696 pcm failure eeprom write denied
p1697 pcm failure sri mile not stored
p1698 no ccd message from tcm
transmission
p0120 tps signal
p0604,605 and p0700 internal trans controller
p0705 check shift signal
p0715 input speed sensor error
p0720 output speed sensor eeror
p0725 engine speed sensor circuit
p0731 gear ratio eeror in 1st
p0732 gear ratio eeror in 2nd
p0733 gear ratio eeror in 3rd
p0734 gear ratio eeror in 4th
p0736 gear ratio eeror in reverse
p0740 tcc control circuit
p0750 l-r solenoid circuit
p0755 2-4 solenoid circuit
p0760 od solenoid circuit
p0765 ud solenoid circuit
p1716 bus communication with engine module
p1738 high temp operation activated
p1739 power-up at speed
p1765 switch battery
p1767 relay output always on
p1768 relay output always off
p1775 solenoid switch latched in tcc position
p1776 solenoid switch latched in l-r position
p1781 od pressure switch sense circuit
p1782 2-4 pressure switch sense circuit
p1784 l-r pressure switch sense circuit
p1787 od hydraulic pressure switch circuit
p1788 2-4 hydraulic pressure switch circuit
p1789 od/2-4 hydraulic pressure switch circuit
p1790 fault after shift
p1791 loss of prime
p1792 battery was disconnected
p1793 trd link communication error
p1794 sensor ground error
p1795 internal trans controller
p1796 autostick input circuit
p1797 manual shift oerheat
p1798 worn out/ burnt trans fluid
p1799 calculated oil temp in use
P0016 crankshaft/camshaft timing misalignment
p0031 o2 sensor 1/1 heater circuit low
p0032 o2 sensor 1/1 heater circuit high
p0037 o2 sensor 1/2 heater circuit low
p0038 o2 sensor 1/2 heater circuit high
p0068 manifold pressure/tps correlation-high flow/vacuum leak
p0070 ambient temp sensor stuck
p0071 ambient temp sensor performance
p0072 ambient temp sensor low
p0073 ambient temp sensor high
p0106 map sensor performance
p0107 map sensor low
p0108 map sensor high
p0110 intake air temp sensor stuck
p0111 intake air temp sensor performance
p0112 intake air temp sensor low
p0113 intake air temp sensor high
p0116 ect performance
p0117 ect sensor low ( engine coolant temp)
p0118 ect sensor high
p0121 tps #1 performance ( throttle position sensor)
p0122 tps #1 low
p0123 tps #1 high
p0125 insufficient coolant temp for close-loop control
p0128 thermostat rationaily
p0129 barometic pressure out of range
p0131 o2 sensor 1/1 volts low
p0132 o2 sensor 1/1 volts high
p0133 o2 sensor 1/1 slow to response
p0135 o2 sensor 1/1 heater performance
p0137 o2 sensor 1/2 volts low
p0138 o2 sensor 1/2 volts high
p0139 o2 sensor 1/2 slow to response
p0141 o2 sensor 1/2 heater performance
p0171 fuel system 1/1 lean
p0172 fiel system 1/1 rich
p0201 thru p0206 fuel injectors
p0300 multiple cylinder mis-fire
p0301 thru p0306 cylinder misfire
p0315 no crank sensor learned
p0325 knock sensor#1 circuit
p0335 crankshaft position sensor circuit
p0340 camshaft position sensor circuit
p0351 thru p0353 ignition coil circuit
p0420 catalytic 1/1 efficiency
p0440 genernal evap system failure
p0441 evap purge system performance
p0442 evap medium leak
p0452 nvld pressure switch sense circuit low
p0453 nvld pressure switch sense circuit high
p0455 evap large leak
p0456 evap small leak
p0461 fuel level sensor #1 performance
p0462 fuel level sensor #1 low
p0463 fuel level sensor #1 high
p0480 low speed fan control relay circuit
p0498 nvld canister vent solenoid circuit low
p0499 nvld canister vent solenoid circuit high
p0500 no vehicle speed signal
p0506 idle speed low performance
p0507 idle speed high performance
p0508 iac valve sense circuit low
p0509 iac valve sense circuit high
p0513 invalid skim key
p0516 battery temp sensor low
p0517 battery temp sensor high
p0519 idle speed performance
p0522 pressure sensor low
p0532 a/c pressure sensor low
p0533 a/c pressure sensor high
p0551 power steering switch performance
p0562 battery volts low
p0563 battery volts high
p0579 speed control switch #1 performance
p0580 speed control switch #1 low
p0581 speed control switch #1 high
p0582 speed control vacuum solenoid circuit
p0586 speed control vent solenoid circuit
p0594 speed control servo power circuit
p0600 serial communication link
p0601 internal memory checksum invalid
p0622 generator field control circuit
p0627 fuel pump relay circuit
p0630 vin not programmed in pcm
p0632 odometer not programmed in pcm
p0633 skim key not programmed in pcm
p0685 asd relay control circuit
p0688 asd relay sense circuit low
p0700 transmission control system - must read tcm with a scanner to get the transmission stores or active codes
p0703 brake switch #2 circuit
p0850 park/neutral switch performance
p1602 pcm not progammed
transmission codes
p0122 tps low
p0123 tps high
p0124 tps intermittent
p0218 high temp operation actived
p0562 low battery volt
p0604,p0605,and p0613 are the same internal tcm
p0706 check shifter signal
p0711,p0712,p0713,and p0714 are trans temp sensor
p0715 input sensor error
p0720 output sensor error
p0731 gear ratio error in 1st
p0732 gear ratio error in 2nd
p0733 gear ratio error in 3rd
p0734 gear ratio error in 4th
p0736 gear ratio error in reverse
p0750 l/r solenoid circuit
p0755 2/4 solenoid circuit
p0841 l/r pressure switch sense circuit
p0845 2/4 hydraulic pressure test failure
p0846 2/4 pressure switch sense circuit
p0870 od hydraulic pressure test failure
p0871 od pressure switch sense circuit
p0884 power up at speed
p0888 relay output always off
p0890 switch battery
p0891 trans relay always on
p0944 loss of prime
p0952 autostick input circuit low
p0953 autostick input circuit high
p0992 2/4-od hydraulic pressure test failure
p1652 serial communication link malfunction
p1684 battery was disconnected
Old Jan 21, 2010 | 06:40 PM
master tech
Default 2008 to 2010 ck engine litr codes (mil)
Diagnosis and Testing
P0016-CRANKSHAFT-CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0051-O2 SENSOR 2/1 HEATER CIRCUIT LOW
P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH
P0057-O2 SENSOR 2/2 HEATER CIRCUIT LOW
P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH
P0071-AMBIENT AIR TEMPERATURE SENSOR PERFORMANCE
P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
P0073-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH
P0107-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW
P0108-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR 1 PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT LOW
P0113-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT HIGH
P0116-ENGINE COOLANT TEMPERATURE SENSOR PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH
P0121-THROTTLE POSITION SENSOR 1 PERFORMANCE - 3.3/3.8L
P0121-THROTTLE POSITION SENSOR 1 PERFORMANCE - 4.0L
P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW - 3.3/3.8L
P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW - 4.0L
P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH - 3.3/3.8L
P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH - 4.0L
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE LOW
P0131-O2 SENSOR 1/1 CIRCUIT LOW
P0132-O2 SENSOR 1/1 CIRCUIT HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0137-O2 SENSOR 1/2 CIRCUIT LOW
P0138-O2 SENSOR 1/2 CIRCUIT HIGH
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P013A-O2 SENSOR 1/2 SLOW RESPONSE - RICH TO LEAN
P013C-O2 SENSOR 2/2 SLOW RESPONSE - RICH TO LEAN
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0151-O2 SENSOR 2/1 CIRCUIT LOW
P0152-O2 SENSOR 2/1 CIRCUIT HIGH
P0153-O2 SENSOR 2/1 SLOW RESPONSE
P0155-O2 SENSOR 2/1 HEATER PERFORMANCE
P0157-O2 SENSOR 2/2 CIRCUIT LOW
P0158-O2 SENSOR 2/2 CIRCUIT HIGH
P0159-O2 SENSOR 2/2 SLOW RESPONSE
P0161-O2 SENSOR 2/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0174-FUEL SYSTEM 2/1 LEAN
P0175-FUEL SYSTEM 2/1 RICH
P0201-FUEL INJECTOR 1 CIRCUIT
P0202-FUEL INJECTOR 2 CIRCUIT
P0203-FUEL INJECTOR 3 CIRCUIT
P0204-FUEL INJECTOR 4 CIRCUIT
P0205-FUEL INJECTOR 5 CIRCUIT
P0206-FUEL INJECTOR 6 CIRCUIT
P0221-THROTTLE POSITION SENSOR 2 CIRCUIT PERFORMANCE - 3.3/3.8L
P0221-THROTTLE POSITION SENSOR 2 CIRCUIT PERFORMANCE - 4.0L
P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW - 3.3/3.8L
P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW - 4.0L
P0223-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH - 3.3/3.8L
P0223-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH - 4.0L
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER 1 MISFIRE
P0302-CYLINDER 2 MISFIRE
P0303-CYLINDER 3 MISFIRE
P0304-CYLINDER 4 MISFIRE
P0305-CYLINDER 5 MISFIRE
P0306-CYLINDER 6 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR 1 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - BANK 1 SENSOR 1
P0401-EGR SYSTEM PERFORMANCE
P0403-EGR CONTROL CIRCUIT/OPEN
P0404-EGR POSITION SENSOR PERFORMANCE
P0405-EGR POSITION SENSOR CIRCUIT LOW
P0406-EGR POSITION SENSOR CIRCUIT HIGH
P0420-CATALYST EFFICIENCY (BANK 1)
P0430-CATALYST EFFICIENCY (BANK 2)
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0443-EVAP PURGE CONTROL CIRCUIT
P0452-EVAP PRESSURE SWITCH STUCK CLOSED
P0455-EVAP SYSTEM LARGE LEAK
P0456-EVAP SYSTEM SMALL LEAK
P0457-LOOSE FUEL CAP
P0461-FUEL LEVEL SENSOR 1 PERFORMANCE
P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW
P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT
P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (with ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (with ABS)
P0506-IDLE SPEED PERFORMANCE LOWER THAN EXPECTED
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXPECTED
P050B-COLD START IGNITION TIMING PERFORMANCE - 3.3/3.8L
P050B-COLD START IGNITION TIMING PERFORMANCE - 4.0L
P050D-COLD START ROUGH IDLE - 3.3/3.8L
P050D-COLD START ROUGH IDLE - 4.0L
P0513-INVALID SKIM KEY
P0522-ENGINE OIL PRESSURE SENSOR CIRCUIT LOW
P0532-A/C PRESSURE SENSOR CIRCUIT LOW
P0533-A/C PRESSURE SENSOR CIRCUIT HIGH
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0571-BRAKE SWITCH 1 PERFORMANCE
P0572-BRAKE SWITCH 1 STUCK ON
P0573-BRAKE SWITCH 1 STUCK OFF
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE
P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW
P0581-SPEED CONTROL SWITCH 1 CIRCUIT HIGH
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION
P0591-SPEED CONTROL SWITCH 2 PERFORMANCE
P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW
P0593-SPEED CONTROL SWITCH 2 CIRCUIT HIGH
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0602-CONTROL MODULE PROGRAMMING ERROR/NOT PROGRAMMED
P0606-INTERNAL CONTROL PROCESSOR
P060B-ETC A/D GROUND PERFORMANCE
P060D-ETC LEVEL 2 APP PERFORMANCE
P060E-ETC LEVEL 2 TPS PERFORMANCE
P060F-ETC LEVEL 2 ECT PERFORMANCE
P061A-ETC LEVEL 2 TORQUE PERFORMANCE
P061C-ETC LEVEL 2 RPM PERFORMANCE
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP CONTROL CIRCUIT
P062C-ETC LEVEL 2 MPH PERFORMANCE
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM SECRET KEY NOT STORED IN PCM
P063A-GENERATOR VOLTAGE SENSE CIRCUIT
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0645-A/C CLUTCH CONTROL CIRCUIT
P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
P0685-ASD/MAIN CONTROL CIRCUIT
P0688-ASD/MAIN SENSE CIRCUIT
P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST)
P0703-BRAKE SWITCH 2 PERFORMANCE
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1004-SHORT RUNNER VALVE CONTROL PERFORMANCE
P1115-GENERAL TEMPERATURE RATIONALITY
P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
P150D-COLD START ROUGH IDLE - OPEN THROTTLE START
P1572-BRAKE PEDAL STUCK ON
P1573-BRAKE PEDAL STUCK OFF
P1593-SPEED CONTROL SWITCH 1/2 STUCK
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1618-SENSOR REFERENCE VOLTAGE 1 ERRATIC
P1628-SENSOR REFERENCE VOLTAGE 2 ERRATIC
P1696-EEPROM MEMORY WRITE DENIED - INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P2008-SHORT RUNNER VALVE (SRV) CONTROL CIRCUIT
P2016-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT LOW
P2017-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT HIGH
P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH
P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT - 3.3L/3.8L
P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT - 4.0L
P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE
P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR
P2110-ELECTRONIC THROTTLE CONTROL SYSTEM - FORCED LIMITED RPM - 3.3/3.8L
P2110-ELECTRONIC THROTTLE CONTROL SYSTEM - FORCED LIMITED RPM - 4.0L
P2111-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO CLOSE - 3.3/3.8L
P2111-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO CLOSE - 4.0L
P2112-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO OPEN - 3.3/3.8L
P2112-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO OPEN - 4.0L
P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE
P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE
P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE - 3.3/3.8L
P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE - 4.0L
P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION - 3.3/3.8L
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION - 4.0L
P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION
P2161-VEHICLE SPEED SENSOR 2 ERRATIC (with ABS)
P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE
P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE
P2172-HIGH AIRFLOW-VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION)
P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION)
P2174-LOW AIRFLOW-RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION)
P2175-LOW AIRFLOW-RESTRICTION DETECTED (SLOW ACCUMULATION)
P2181-COOLING SYSTEM PERFORMANCE
P2271-O2 SENSOR 1/2 SIGNAL STUCK RICH
P2273-O2 SENSOR 2/2 SIGNAL STUCK RICH
P2299-BRAKE PEDAL POSITION - ACCELERATOR PEDAL POSITION INCOMPATIBLE
P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 3.3/3.8L
P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 4.0L
P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 3.3-3.8L
P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 4.0L
P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 3.3-3.8L
P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 4.0L
P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2503-CHARGING SYSTEM OUTPUT LOW
P2504-CHARGING SYSTEM OUTPUT HIGH
P2533-IGNITION SWITCH RUN/START POSITION CIRCUIT
P2610-ECM/PCM INTERNAL ENGINE OFF TIMER PERFORMANCE
U0001-CAN C BUS
U0002-CAN C BUS OFF PERFORMANCE
U0101-LOST COMMUNICATION WITH TCM
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM)
U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN)
U110C-LOST FUEL LEVEL MESSAGE
U110E-LOST AMBIENT TEMPERATURE MESSAGE
U110F-LOST FUEL VOLUME MESSAGE
U1110-LOST VEHICLE SPEED MESSAGE
U1113-LOST A/C PRESSURE MESSAGE
U1120-LOST WHEEL DISTANCE MESSAGE
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
Standard Procedure
CHECKING FOR AN INTERMITTENT DTC
PCM / TCM PROGRAMMING
PCM VERIFICATION TEST
PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE
MODULE, Powertrain Control (PCM), 62TE
P0122-TPS/APP CIRCUIT LOW
P0123-TPS/APP CIRCUIT HIGH
P0124-TPS/APP INTERMITTENT
P0218-HIGH TEMPERATURE OPERATION ACTIVATED
P0604-INTERNAL CONTROL MODULE RAM
P0605-INTERNAL CONTROL MODULE ROM
P0613-INTERNAL TRANSMISSION PROCESSOR
P0706-TRANSMISSION RANGE SENSOR RATIONALITY
P0711-TRANSMISSION TEMPERATURE SENSOR PERFORMANCE
P0712-TRANSMISSION TEMPERATURE SENSOR LOW
P0713-TRANSMISSION TEMPERATURE SENSOR HIGH
P0714-TRANSMISSION TEMPERATURE SENSOR INTERMITTENT
P0716-INPUT SPEED SENSOR 1 CIRCUIT PERFORMANCE
P0721-OUTPUT SPEED SENSOR CIRCUIT PERFORMANCE
P0726-ENGINE SPEED INPUT CIRCUIT RANGE/PERFORMANCE
P0729-GEAR RATIO ERROR IN 6TH
P0731-GEAR RATIO ERROR IN 1ST
P0732-GEAR RATIO ERROR IN 2ND
P0733-GEAR RATIO ERROR IN 3RD
P0734-GEAR RATIO ERROR IN 4TH
P0735-GEAR RATIO ERROR IN 5TH
P0736-GEAR RATIO ERROR IN REVERSE
P0740-TCC OUT OF RANGE
P0750-L/R SOLENOID CIRCUIT
P0755-2/4 SOLENOID CIRCUIT
P075A-LC SOLENOID CIRCUIT
P0760-OD SOLENOID CIRCUIT
P0765-UD SOLENOID CIRCUIT
P076A-DC SOLENOID CIRCUIT
P0791-TRANSFER SPEED SENSOR CIRCUIT
P0792-COMPOUNDER SPEED RATIO ERROR
P083A-LC HYDRAULIC PRESSURE TEST
P083B-LC PRESSURE SWITCH RATIONALITY
P0841-L/R PRESSURE SWITCH RATIONALITY
P0845-2/4 HYDRAULIC PRESSURE TEST
P0846-2/4 PRESSURE SWITCH RATIONALITY
P084A-DC HYDRAULIC PRESSURE TEST
P084B-DC PRESSURE SWITCH RATIONALITY
P0868-LINE PRESSURE LOW
P0869-LINE PRESSURE HIGH
P0870-OD HYDRAULIC PRESSURE TEST
P0871-OD PRESSURE SWITCH RATIONALITY
P0882-TCM POWER INPUT LOW
P0883-TCM POWER INPUT HIGH
P0884-POWER UP AT SPEED
P0888-TRANSMISSION RELAY ALWAYS OFF
P0890-SWITCHED BATTERY
P0891-TRANSMISSION RELAY ALWAYS ON
P0897-TRANSMISSION FLUID DETERIORATED
P0932-LINE PRESSURE SENSOR CIRCUIT
P0934-LINE PRESSURE SENSOR CIRCUIT LOW
P0935-LINE PRESSURE SENSOR CIRCUIT HIGH
P0944-LOSS OF HYDRAULIC PUMP PRIME
P0957-AUTOSTICK CIRCUIT LOW
P0992-2/4/OD HYDRAULIC PRESSURE TEST
P1684-BATTERY WAS DISCONNECTED
P1713-RESTRICTED MANUAL VALVE IN T2 RANGE
P1741-GEAR RATIO ERROR IN 4 PRIME
P1745-TRANSMISSION LINE PRESSURE TOO HIGH FOR TOO LONG
P1770-INADEQUATE ELEMENT VOLUME LR
P1771-INADEQUATE ELEMENT VOLUME 2/4
P1772-INADEQUATE ELEMENT VOLUME OD
P1775-SOLENOID SWITCH VALVE LATCHED IN TCC POSITION
P1776-SOLENOID SWITCH VALVE LATCHED IN LR POSITION
P1790-FAULT IMMEDIATELY AFTER SHIFT
P1794-SPEED SENSOR GROUND ERROR
P1797-MANUAL SHIFT OVERHEAT
P273A-INADEQUATE ELEMENT VOLUME LC
P273B-INADEQUATE ELEMENT VOLUME DC
P2763-TORQUE CONVERTER CLUTCH PRESSURE CONTROL CIRCUIT HIGH
P2764-TORQUE CONVERTER CLUTCH PRESSURE CONTROL CIRCUIT LOW
U0100-LOST COMMUNICATION WITH THE ECM/PCM
U0121-LOST COMMUNICATION WITH ABS
Old Oct 13, 2010 | 11:02 PM
master tech
Default 2001 to 2007 mil codes (gas)
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
P0071-AMBIENT TEMP SENSOR PERFORMANCE
P0072-AMBIENT TEMP SENSOR LOW
P0073-AMBIENT TEMP SENSOR HIGH
P0107-MAP SENSOR LOW
P0108-MAP SENSOR HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR LOW
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
P0116-ENGINE COOLANT TEMPERATURE PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR HIGH
P0122-THROTTLE POSITION SENSOR #1 LOW
P0123-THROTTLE POSITION SENSOR #1 HIGH
P0131-O2 SENSOR 1/1 VOLTAGE LOW
P0137-O2 SENSOR 1/2 VOLTAGE LOW
P0132-O2 SENSOR 1/1 VOLTAGE HIGH
P0138-O2 SENSOR 1/2 VOLTAGE HIGH
P0141-O2 SENSOR 1/2 HEATER PERFROMANCE
P0201-FUEL INJECTOR #1
P0202-FUEL INJECTOR #2
P0203-FUEL INJECTOR #3
P0204-FUEL INJECTOR #4
P0205-FUEL INJECTOR #5
P0206-FUEL INJECTOR #6
P0301-CYLINDER #1 MISFIRE
P0302-CYLINDER #2 MISFIRE
P0303-CYLINDER #3 MISFIRE
P0304-CYLINDER #4 MISFIRE
P0305-CYLINDER #5 MISFIRE
P0306-CYLINDER #6 MISFIRE
Page 1
Old Oct 13, 2010 | 11:10 PM
master tech
Page 2
P0344-CAMSHAFT POSITION SENSOR INTERMITTED
P0401 - EGR SYSTEM PERFORMANCE
P0403 - EGR CONTROL CIRCUIT
P0404 - EGR POSITION SENSOR PERFORMANCE
P0405 - EGR POSITION SENSOR LOW
P0406 - EGR POSITION SENSOR HIGH
P0420-CATALYTIC 1/1 EFFICIENCY
P0442-EVAP SYSTEM MEDIUM LEAK
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-NVLD PRESSURE SWITCH SENSE CIRCUIT LOW
P0453-NVLD PRESSURE SWITCH SENSE CIRCUIT HIGH
P0461-FUEL LEVEL SENSOR #1 PERFORMANCE
P0462-FUEL LEVEL SENSOR #1 LOW
P0463-FUEL LEVEL SENSOR #1 HIGH
P0498-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT LOW
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (AUTO TRANS)
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (MANUAL TRANS)
P0506-IDLE SPEED LOW PERFORMANCE
P0507-IDLE SPEED HIGH PERFORMANCE
P0508-IAC VALVE SENSE CIRCUIT LOW
P0509-IAC VALVE SENSE CIRCUIT HIGH
P0522 PRESSURE SENSOR LOW
P0532-A/C PRESSURE SENSOR LOW
P0533-A/C PRESSURE SENSOR HIGH
P0572-BRAKE SWITCH #1 CIRCUIT LOW
P0573-BRAKE SWITCH #1 CIRCUIT HIGH
P0580-SPEED CONTROL SWITCH #1 LOW
P0581-SPEED CONTROL SWITCH #1 HIGH
P0582-SPEED CONTROL VACUUM SOLENOID CIRCUIT
P0586-SPEED CONTROL VENT SOLENOID CIRCUIT
P0594-SPEED CONTROL SERVO POWER CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0645-A/C CLUTCH RELAY CIRCUIT
P0685-ASD RELAY CONTROL CIRCUIT
P0688-ASD RELAY SENSE CIRCUIT LOW
