2004 dodge caravan front blower
Old Jan 12, 2010 | 11:10 PM
SeaverTam's Avatar
SeaverTam
Default 2004 dodge caravan front blower
Hey,
I have a problem with my front blower in my 2004 caravan......it just stopped working. First thought was a fuse, but fuses under the hood checked out fine. Any ideas on what could be happening here and what I can do about it? Also, is there an interior fuse box, can't seem to find one.
Old Jan 13, 2010 | 07:06 AM
92dak5.24x4's Avatar
92dak5.24x4
did you ever think that the blower motor itself failed? It's amazing how electric motors work then suddenly fail.
Old Jan 14, 2010 | 04:29 PM
Tizzy1's Avatar
Tizzy1
It is usually the blower motor resistor (located behind the glove box). The resistor fails because the blower motor is drawing too much current. If a test light shows power to both terminals of the blower motor, you need to replace the blower motor and the resistor. Installing a blower motor is a pain in the butt...FYI.
Old Jan 14, 2010 | 05:04 PM
92dak5.24x4
if the blower motor resitor fails, you still have high speed. because high completely by-passes the resistor!
Old Jan 14, 2010 | 10:23 PM
Tizzy1's Avatar
Tizzy1
If the thermal blows, which is what fails, you lose all speeds. This is the wiring diagram for an '04 manual temp control system.
