2007 GCV 3.8 whining
Old Jan 14, 2010 | 11:34 PM
fullmote60's Avatar
fullmote60
Default 2007 GCV 3.8 whining
i have a 2007 GCV SXT w/3.8L that will whine when started i the cold but the whine will go away after the engine is warm. any clues? thanks
Old Jan 15, 2010 | 11:07 AM
master tech's Avatar
master tech
Site Moderator & Tech
The whine sound you maybe hearing is from the power steering reservoir. It maybe low or the filter inside is a bit plugged. You may want to replace the reservoir and replace the p/s fluid to atf+4. If the fluid is low, ck the steering system for any leaks.
Old Jan 15, 2010 | 12:00 PM
circumventor's Avatar
circumventor
it'd be nise to know like ware teh sound is like pass side, drive side, id think that if the ps pump was the prob the steering would be stifer cold vs hot.
Old Jan 15, 2010 | 12:24 PM
fullmote60's Avatar
fullmote60
thanks. tomorrow will be warm enough to actually get under the hood & listen a little closer.
Old Jan 15, 2010 | 04:43 PM
circumventor
@ even -30 id be under the hood to figgure out wtf is wrong w. my van. so does teh noise change when yall turn the wheels? if it aint then prolly not the pow str.
Old Jan 15, 2010 | 07:44 PM
fullmote60's Avatar
fullmote60
no, something that spins though, for sure. tensioner maybe.
Old Jan 15, 2010 | 09:00 PM
92dak5.24x4's Avatar
92dak5.24x4
I think what the illiterate guy is saying, when you hear the whinning and steer the wheels back and forth, does the pitch of the whinning change?
Old Jan 15, 2010 | 09:13 PM
fullmote60's Avatar
fullmote60
no, it seems more rpm based which makes it more strange that it stops when it gets up to operating temp. i'll open her up in the a.m. and look & listen.
Old Jan 16, 2010 | 09:58 AM
fullmote60's Avatar
fullmote60
92dak- yes, that is the case. before i started it i made sure there wasn't anything loose or flopping around under the hood. after i started it the noise began, not as loud b-cuz it wasn't as cold, but when i turned the steering wheel from side to side you could hear it.
Old Jan 16, 2010 | 10:09 AM
fullmote60's Avatar
fullmote60
this link has a good explanantion> http://www.ricksfreeautorepairadvice...ysler-vehicles
