banging noise from front end
Old Jan 16, 2010 | 01:41 PM
2damnyankee's Avatar
2damnyankee
Default banging noise from front end
Ok I have a 2002 town and country. I have a really bad banging noise in the front end. I have changed out the front struts and rear shocks all monroe sensa trac, now the banging is worse I can feel it in the floor boards on both sides. I was thinking that it could be the motor mounts but wanna get someone else's idea of what it could be. If anyone had the same issue and found out what it was please let me know this is driving me nuts.
Old Jan 16, 2010 | 03:59 PM
Tizzy1's Avatar
Tizzy1
there are issues with the sway bar links and the sway bar bushings. If you notice more over bumps, links. If it's more body twist, like swerving back and forth, then the bushings are bad. Sounds more like links to me.
Old Jan 18, 2010 | 08:08 PM
crazdandconfusd's Avatar
crazdandconfusd
I'm new to the forum and I'm having the same issue with a rattling sound from the front end of my 04 Ram 1500 5.7L Quad Cab. My problem is with the end links, but after I replace them, the noise stops for about a week. I've used MOOG from Advanced Auto Parts and ProSteer from PepBoys. Are there any others on the market that will outlast the previous two?
Old Jan 19, 2010 | 10:46 PM
82prospector's Avatar
82prospector
You can check motor mounts thusly:
Open hood (you'll understand why in a moment)
Start the engine
While looking thru the bottom edge of the hood keep an eye on the engine
With a foot on the brake shift into any forward gear
Take note of how much the engine moves
With foot still on brake, move shifter to reverse and note engine movement
Repeat as needed to ascertain excessive movement. Listen for clunks etc when shifting from forward to reverse. Disregard any buzzing noises from the transmission etc, you're only concerned with clunks related to drivetrain movement.
Regarding your strut replacement, did they install new hats? What's the condition of the control arm bushings, ball joints, cv boots etc. A good mechanic will always take the holistic approach and not turn a blind eye to other needed repairs.
