Indicator Flasher problem
Old Jan 19, 2010 | 01:11 AM
dburroughs's Avatar
dburroughs
Default Indicator Flasher problem
Hi Folks
Maybe someone here can help with an electrical issue. I have a 1997 Dodge Caravan and just recently have been having an intermittent problem with my left turn indicator either jamming or not working at all. I already replaced the bulbs at the back , I even switched the right indicator assembly onto the left plug and all the bulbs worked and the indicator was working at the time. Now in order to make the left indicator work when it stops responding I have to put on the hazards for a while having the steering column switch indicating left (down). Once the hazzard switch is shutoff the left indicator starts to work again. Is this the sign of a failing relay? Remember the right indicator is still working just fine, the problem is only with the left one.
Old Jan 19, 2010 | 09:53 AM
master tech's Avatar
master tech
Site Moderator & Tech
Your van has what is called a combo flasher. It two flasher in one. Either find or buy a known good combo flasher and recheck.
Old Jan 20, 2010 | 10:39 AM
dburroughs's Avatar
dburroughs
Are you talking about the module which controls the hazards, daylights, and indicators. Is it a rectangular shape with I think eight prongs and located beneath the driver side dash? Is this combo flasher designed to operate the indicators independent of one another?
Old Jan 20, 2010 | 11:16 AM
Tizzy1's Avatar
Tizzy1
It has nine pronges, there is one with daytime running lights and one without. It sits right above the row of fuses down by your left foot. It is very common for them to do that, fail just on one side but work the other.
