HELP...No Headlights Town & Country
Old Apr 20, 2005 | 03:02 PM
Eltoolo's Avatar
Eltoolo
Default HELP...No Headlights Town & Country
Thanks, we got it fixed, after trying our selves to replace the headlight switch, high/low beam switch. It turned out to be the body control module.
Hi,
We have no headlights or foglight, but everything else. We have checked the following: Fuse, relay and bulbs.
I just was wondering if anyone else has had this problem? We think it may be the switch but not sure how to test it. We can not afford to bring it to the dealer for $125 just to look at it.....I have 2 kids and not being able to drive at night is not good.
Any help would be great!!!!!!!
Old May 11, 2005 | 10:08 AM
brandoncrone's Avatar
brandoncrone
Default RE: HELP...No Headlights Town & Country
It could be a number of things, turn signal switch, wiring to the headlamps (I've seen them break above the right front wheel), body control module(actually turns the headlights on) or the switch itself. Good luck!
Old Jun 19, 2005 | 06:05 PM
GeorgiaVan's Avatar
GeorgiaVan
Saw your post re: headlights not working... I have a 97 Dodge G/C-van. All exterior lights stopped working via the dashboard switch. Brake lights and backup lights work with respective function... Can pull steering column lever and high beams come on, but again -- nothing with the dashboard console switch... Everything else works fine. Called dealer -- he said BCM $700.... Wondering if any other options.. Seems rather extreme...
Thanks.
