05 caravan
Old Jan 20, 2010 | 12:33 PM
v10rams's Avatar
v10rams
Cool 05 caravan
05 caravan remotes not working for power locks, new batteries still not working, pl work from inside doors. any help?
Old Jan 20, 2010 | 01:05 PM
Tizzy1's Avatar
Tizzy1
key and fob together?
Old Jan 20, 2010 | 01:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If the remote weren't working before you replace the battery, then the problem maybe the circuit board inside the remote. Most dealers have a RKE tester to test the signal on the remote. I don't if anyone else would. I would have the remote tested and replace if needed. Are the door locks working with door switches?
Old Jan 22, 2010 | 01:31 PM
v10rams's Avatar
v10rams
none of the three remotes work or does the power lock switches.
Old Jan 22, 2010 | 01:33 PM
v10rams's Avatar
v10rams
i ran a computer scan and it has a code v110u, any ideas what this code is the scanner has no defs, on it
Old Jan 22, 2010 | 03:27 PM
master tech
Okay, There a TSB to flash the door modules. Because of the door locks, but you need to have the dealer to hook up the DRB3 and ck for stored codes. And then clear them and perform the flash update.
