Replacing 3.3 l
Old Jan 29, 2010 | 01:32 PM
snakeoil's Avatar
snakeoil
Question Replacing 3.3 l
The 3.3l in our 98 Caravan will need replacing soon as it has over 300,000 kms on it. What is the range of years that I could use when buying a used 3.3 - It is not a flex fuel. Don't mind some simple adaptation if necessary.
Thanks, JJ
Old Jan 29, 2010 | 02:52 PM
92dak5.24x4's Avatar
92dak5.24x4
Why replace it based on that low of use? These engines easily run 600,000km with good maintenance. The highest un-touched 3.3 for miles was 500,000 Miles not km and still running strong. It went thru 3 transmissions but still the same engine. You can use any gen3 3.3 as a direct fit. a flex fuel engine would require changing injectors...bfd. There is some sensors that changed plug designs over the years but that' very easy to accomidate
