Check engine light help
Old Jan 30, 2010 | 02:15 PM
ALSAMP's Avatar
ALSAMP
Default Check engine light help
I have a 2004 grand caravan with the 3.3, it has 64000 miles on it. the check engine light is on and it codes that there is a leak at fill neck assembly. i cannot find any leaks but i can smell gas under the hood on the drivers side. it smells stronger under the power steering resevour. i dont see any gas lines or anything around there any help would be greatly appreciated thanks.
Old Jan 30, 2010 | 09:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know want the code was for the ck engine lite. On the fuel smell, i would look at the fuel line and injectors.
