Recirculation Control Problem
Hi Gang!
new kid on the block here with a Grand Caravan (year 2000) problem...
lately I am getting quite a lot of windows fogging on the inside (even if only the driver in the car) as if the air is never fresh coming in from the outside.
Checked the vents in the front, they are clean, etc.
I am suspecting the recirculation flap for some reason being stuck, thus fresh dry air never enters the car and fogging occurs (the recirculation button is not on).
I have to get the defrost going every 5 minutes of driving or so, to defog the windshield so I can see where I'm driving.
Anyone has any words of wisdom on this issue? It would be greatly appreciated!! Thanks a lot!
Cheers,
gabstero
Cheers,
gabstero
RECIRC DOOR ACTUATOR
REMOVAL
Pull back on carpeting on the right lower floor.
Remove Recirc. door actuator connector.
Remove (3) mounting screws for Recirc. actuator Recirculation Door Actuator
Remove Recirc. actuator.
Disengage actuator linkage at Recirc. door.
Remove actuator from vehicle.
INSTALLATION
For installation, reverse the above procedures.
Perform the HVAC control Calibration Diagnostic and Cooldown test.
REMOVAL
INSTALLATION
MT -
Thanks a ton for the tips! That did it - i just had to remove the three screws and push the button while doing it - the door was stuck. Popped it back in - worked like a charm!
Thanks a ton again!
Gabstero
Thanks a ton again!
Gabstero
