2002 Caravan ~Help~ No head Lights
Old Feb 3, 2010 | 07:58 AM
NastyBoy89's Avatar
NastyBoy89
Default 2002 Caravan ~Help~ No head Lights
My Head Lights Stopped Working
About a year ago my driver side headlight stopped working and then the headlight came back on about a week later, It was fine for about 6 months, Then the passenger Side daytime runner light stopped working…. When I turned on the headlights the driver side Daytime runner light stopped working then the passenger side day time runner light started working, plus only the driver side headlight would only come on.
Today the only thing that works is the driver side daytime runner and high beams (No Headlights)
I changed the head light and it did not fix the problem
Can anyone please help Me
Thanks
Old Feb 3, 2010 | 10:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have high beams? If you do high beams, i would ck with dealer for a FCM update. I have seen a flash took care of a headlamp problem.
Old Feb 3, 2010 | 04:39 PM
Tizzy1's Avatar
Tizzy1
you want to remove the front control module and check the fuse box for spread terminals. Very common problem in my neck of the woods.
Old Feb 3, 2010 | 05:37 PM
Tizzy1's Avatar
Tizzy1
I'm sure I have posted the wiring diagram on another thread. If you need it, let me know.
