no flashing lights when activating keyless entry
Old Feb 3, 2010 | 11:46 PM
soap dodger's Avatar
soap dodger
Default no flashing lights when activating keyless entry
For some strange reason, the tail and headlights have suddenly stopped flashing on my 2006 SE Grand Caravan when locking or unlocking using the keyless entry. It is anything the wife could have messed with??
Thanks.
Old Feb 3, 2010 | 11:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Has any work have been done to the van? You may need a scanner to inable the system.
Old Feb 4, 2010 | 07:27 AM
soap dodger
no MT, no work has been done to the van.
Old Feb 4, 2010 | 10:04 AM
master tech
You may need the dealer for this. They have a DRB3 and can ck the BCM and inable the system.
Old Feb 4, 2010 | 11:28 AM
Tizzy1's Avatar
Tizzy1
this is from an '07 owners manual but I am assuming '06 is the same
To Turn Off “Flash Lights On Lock/Unlock” — If
Equipped
If desired, the “Flash Lights On Lock/Unlock” feature
can be turned on and off by performing the following
procedure:
1. Press the LOCK button for 5 to 10 seconds.
2. While the LOCK button is pressed, (after 5 seconds)
press the UNLOCK button. Release both buttons.
The “Flash Lights On Lock/Unlock” feature can be
reactivated by repeating this procedure or by performing
Old Feb 4, 2010 | 11:29 AM
Tizzy1's Avatar
Tizzy1
the horn chirp can also be turned on and off in a similar manner.
Old Feb 5, 2010 | 08:56 AM
soap dodger
tried, but doesn't work.
Old Feb 5, 2010 | 09:31 AM
Tizzy1's Avatar
Tizzy1
sometimes it takes a few or more times. Very fussy system.
